VRayCompleteMap
  • VRayCompleteMap
    In 3ds max using "Render to Texture" its very easy to bake VRayCompleteMap, But in Maya i didn't found any similar option.
    I tried using "vrayBakeOptions" & "Bake With VRay" but not getting output similar to what i want..
    Trying to do same thing present in below video inside Maya instead of 3ds max, See this
    https://www.youtube.com/watch?v=hy_o...tu.be&t=11m09s
    You have to bake the "Beauty" pass in Maya and if you need any additional passes like Lighting, just add the corresponding render element.
    Tashko Zashev | chaos.com
      Its a Bug in Version 2.45.01 ,,i tried with 3.10.01 & its working fine
        Btw you can directly bake to a vertex color set in Maya, so you can skip a part of that tutorial...
          Cool..can you explain how?
          I m searching alternative solution for translucencyMod.
