Vray 3.0 Render Shortcut
  • Vray 3.0 Render Shortcut
    I have a hotkey in maya to render the current image ("redoPreviousRender render")
    That worked greate in Vray 2.45 but I have problems using it in vray 3.0. It only works if I click into a Maya Window before pressing the hotkey.
    If I click the VFB it doesn't work.
    Is there any Solution for that?
    I'm using maya 2014
    I got the same behavior here with V-Ray 3.x - when VFB windows is on focus Maya shortcuts do not work.
    I'll report it as a bug if it works fine with version 2.x.
      I can confirm it works fine in version 2.x.
      A note about it has been added into our system.
        Have the same problem in VRay Next...
          Seems to work fine here with V-Ray Next:
          What is the exact V-Ray and Maya version on your side and what is the shortcut setup?
