Vray not working
  • Vray not working
    Couldn't obtain license (4096) message is shown when start vray render in sketchup 2014
    Sounds like perhaps your dongle is not plugged in? Or you are pointing at a license server that is invalid
    Joe Bacigalupa
    Developer
    Chaos Group
      exactly the same problem, sketchup 2016 x64, vray 3.4 b1, windows 10 x64, also set wibu key[IMG]‪D:\Screenshot_1.png[/IMG]
        [QUOTE=Dimax3dd;713917]exactly the same problem, sketchup 2016 x64, vray 3.4 b1, windows 10 x64, also set wibu key "Failed to checkout V-ray gui license"
          Try re-installing. We've moved away from Dongle based licensing and there can sometimes be a conflict between v2 and v3 licensing. If the issue persists please email support@chaosgroup.com
          Best,
          Ted Vitale
          V-Ray for SketchUp
          Product Manager | V-Ray SketchUp
          Chaos Group
            The same problem here...
              Hi All,
              Upon your first installation, if you don't login when prompted you may run into this issue. Here is some additional information that might be helpful:
              The full set up and install documentation page can be found here: https://docs.chaosgroup.com/display/...d+Installation
              Just Install: https://docs.chaosgroup.com/display/...y+for+SketchUp
              Managing the new Online License Server: https://docs.chaosgroup.com/display/...line+Licensing
              Hope that helps, and if any of you are still getting issues, please email support@chaosgroup.com for further licensing assistance.
              Best,
              Ted Vitale
              V-Ray for SketchUp
              Chaos Group
