doing a wireframe render in rhino
  • doing a wireframe render in rhino
    have one class project for a friend who needs to render in rhino but in wireframe mode, in 3ds max its very simple but how is this done in rhino?
    Architectural and Product Visualization at MITVIZ
    http://www.mitviz.com/
    http://mitviz.blogspot.com/
    http://www.flickr.com/photos/shawnmitford/
    i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
    Depending on the version of V-Ray for Rhino you are using and the effect you are looking for, there are several ways you can proceed:
    - Use ToonMtl. If you want transparency you can set the base material's opacity to 0.
    - Use VrayEdgesTex in the Diffuse and (optionally) Opacity map slots.
    - Use the Capture Viewport to File button (ViewCaptureToFile) while in Wireframe/Technical/Pen mode and combine the image in a photo-editing software of your choice with a rendered image of the same view, size and aspect ratio.
    Peter Chaushev
    Let's keep in touch
      thanks for the reply we did it like that but no one took the time to even respond intime i guess vray for rhino is dead
        We apologize for this situation. We are making the necessary changes to avoid this to happen again.
        V-Ray for Rhino is not dead, we are currently is a close beta process and we are going to open the beta for the public very soon.
        We have a new UI and a lot of new features. We are using the same core as V-Ray for 3ds Max 3.4. therefore we have access to the latest V-Ray technology. Our render is 50%+ faster than V-Ray 2.0. We have features like Denoiser, Round edges, SSS2, Fur, Hair material, Carpaint, Stochastic flakes, Blend materials, clipper plane, mesh light and much more.
        I would like to include you to the close beta process, so, you can take advantage of all this tool right now.
        Please, let me know if this is something you would like to do.
        Best
          Best
          hi, sounds awesome but i hardly use it and am mostly assisting students with their student licenses
            Wire frame and curve renders? You could think about to use the Rhino render tool _CurvePiping. So you would render curves as light wight mesh objects.
