why the liquid can't be rendered?
  • why the liquid can't be rendered?
    hi,my friend is using phoenix fd adv 2200 for max 2016.yesterday he found a problem about this plug-in:he can't render the liquid created by phoenix fd,only the foam&splash can be renderd.is it a bug?how to solve the problem?[IMG][/IMG][/IMG]
    Maybe the render mode in the Rendering panel is not Mesh?
      no,he set the render mode Mesh[IMG][/IMG]
        can you select the simulator and type in the listener $.surflevel ?
        ______________________________________________
        VRScans developer
          yes,i got 1000 in the response.
            [IMG][/IMG]
              Yup, so try
              $.surflevel = 0.5
                Could you just check the About box in the Simulation panel and paste here the Build ID?
                    what does surflevel mean to phoenix fd? why the default value is so high that the liquid can't be rendered?
                      a legacy problem, phoenix started as fire/smoke simulator and this value was used to render fires as liquid, it's considered to be the border temperature of the flame.
                      VRScans developer
