maya crashes when updating the alembic file for a vray proxy
  • maya crashes when updating the alembic file for a vray proxy
    bug report (maya 2016 linux, vray for maya 3.40.02):
    1. create vray proxy from alembic file
    2. render
    3. externally overwrite/update the alembic file
    4. hit render again, very likely maya crashes
    as a work-around, usually re-opening the maya scene or restarting maya helps
    anybody else seen this?
    I can't manage to reproduce the crash. Does it occurs only with a particular .abc file? If yes can you send it over to support?
    Also do you override the file with another one or you update the alembic geometry?
