Phoenix Ocean 360 VR render
  • Phoenix Ocean 360 VR render
    Hello!
    How do you render phoenix ocean for VR 360 spherical camera?
    When i render it but ocean surface gets cut by camera view region. Is there a way to turn this cam region off?
    Thank you!
    That's unfortunately one of the things we have yet to implement. You could render 6 separate cameras for a cubic render, but it might be somewhat complicated to set up.
      Oh.. too bad.
      Anyway, thank you, Vlado!
        It's one of the tasks with higher priority right now though. I hope we can get to it soon.
        Cheers!
          I am just bumping the thread. I have the same issue. The camera is set to spherical panorama from VRay settings and the ocean gets cut off. Also noticed even with normal camera sometimes you can spot that the sun shadow is cut at the end of the ocean etc. It's great for optimisation of the scene but it would be even greater if it could be overridden somehow. Many thanks Chaos team
            Have not had a chance to test, but what if you point the camera straight down and make the FOV 180. Surely that should give you the full ocean in the 360.
            You will just have to do post reorientation. Might work as a work around for now.
            Gavin Jeoffreys
            Freelance 3D Generalist
              Hello! Any progress on this topic?
                Not yet, I'm afraid.
                Georgi Zhekov
                Phoenix Product Manager
                Chaos
                  Eh.. too bad, guys. In last trends VR/Panorama renders become very popular. So this feature is really needed these days. I hope you will pay some attention in this direction and add panorama render to phoenix
                  Cheers!
                    any update on this topic ?
                    PC Specs: CPU i9-14900K - GPU RTX 4090 - RAM 192GB 5200MHz - MB Asus ROG Maximus Dark Hero
                      Nope, not yet. It is gonna take a while until we are done with our current tasks.
                      Cheers!
                        Hi, is there a fix to this, or a workaround, rendering some ship VR and the sea is missing in places.
                          Hello,
                          We're working on this and it should be in the nightlies quite soon.
                          Georgi Zhekov
                          Chaos
                            Hello! I understand that this feature has been implemented, but I just can't figure out how to enable it.
                            I have version of Phoenix 3.14, but for some reason the ocean is cropped when rendering. Are there sequential steps you need to take to get this to work?
                            For some reason, a black line is displayed at the bottom ...
                            • #15
                              If you check the Override FOV box, then it turns out like this
                              https://ibb.co/2sXVD9C
                              What to do?
