Question regarding V-Ray frame Buffer and Render Elements...
  • Question regarding V-Ray frame Buffer and Render Elements...
    I'm using Vray 3.4 with 2014 3DS Max. I've added Global illumination, Vray Lighting, Vray Shadows and Vray Sample rate to the Render Elements Tab. However once my render is complete and I go to the frame buffer to view the individual channels, other than RGB and Sample rate, they appear as a black image.
    The renderer I'm using is Vray. Has anybody experienced this? Any suggestions much appreciated. Even basic ones - I'm a newbie.
    Can you post the scene file for this issue?
    This could happen if you are using unsupported materials.
    Tashko Zashev | chaos.com
      Hi Tashko,
      Thanks for your reply. I've only just checked back now and seen your reply. I worked out the problem. Cheers,
        Originally posted by jameslevack View Post
        Hi Tashko,
        may i know how you solve your problem?
        Jackie Teh
        3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
        AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
        Website: https://www.sporadicstudio.com
        Email: info@sporadicstudio.com
        YouTube: https://www.youtube.com/c/SporadicStudio
