Vray RT does not render lights - help
  • Vray RT does not render lights - help
    I am trying to render out lights in revit. The revit render engine does show them just fine but when i use gray RT they do not illuminate. what am i doing wrong?
    I am downloading the lights from companies with the IES files, but only one particular light is rendering the source while the others do not.
    Do you get any error messages?
    Which version of V-Ray|Revit do you use? (you can find it in the About box after expanding the Help menu)
    Ana Lyubenova
    Product Manager
    www.chaos.com
      yes there are yellow text saying " [WARNING] V-Ray: Could not load IES File C:" I checked the lights and the photometric web is in the family and the folder
      I am using the Vray 3.4
        I'm asking about the version V-Ray|Revit at the bottom of the About box (e.g. 3.40.02)
        Ana Lyubenova
        Product Manager
        www.chaos.com
          sorry
          V-Ray | Revit Version 340.02
          V-Ray Core Version 3.40.4
            Can you try to replace the IES files with any of the generic Revit IES files; and then message me the result.
            Revit IES content is stored here: C:\ProgramData\Autodesk\RVT 2017\IES
            Ana Lyubenova
            Product Manager
            www.chaos.com
              no luck :/
              i went ahead and changed them to generic ies files and still no luck. I did realize that some of the IES files i downloaded did not make it over to that folder. i moved the IES files into RVT2017/IES thinking that would solve it but Vray RT is still not allowing the lights to render.
              I am aware that some IES files i do not have hence the warnings, but the other lights i should have no issues with?
              I attached screen shots of both revit render and vray rt below
Name:	revit render.jpg
Name:	vray rt render.JPG
Name:	revit render 2.jpg
Name:	vray rt render 2.JPG
                We are aware of such problem which will be fixed in our next update.
                Until then can you try the workaround described in the following thread: https://forums.chaosgroup.com/showth...p-render-error
                Let me know the result.
                Ana Lyubenova
                Product Manager
                www.chaos.com
