Ocean rendering with spherical cam
  • Ocean rendering with spherical cam
    Hi all,
    Presumably I can't post in the problems forum because I don't have a license myself but the studio I'm working for at the moment has one.
    I'm trying to add a phoenix ocean to a HDRI sky and then render it out for use as a HDRI. I think the ocean isn't recognising that I've set the camera to spherical + 360 FOV and isn't rendering it. Is there a way to solve this?
    I've attached the render below.
    Cheers,
    Max
    Freelance 3D Generalist
    www.maxwood.co.uk
    Hello,
    Currently this feature is not supported but it's in the to do list so I hope we can get to it soon.
    Thanks,
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Originally posted by georgi.zhekov View Post
      Hello,
      Thanks,
      No problem, I'll find another way for now. Thanks Georgi.
      www.maxwood.co.uk
        If it's just an ocean surface you need, you could just use a plane with vraydisplacement using the ocean texture.
        Gavin Jeoffreys
          That would work nicely, thanks for the suggestion Gavin! As you can probably tell I'm quite new to Phoenix
          www.maxwood.co.uk
            ... and make the Sun invisible to avoid the white spots in the water.
