VRay Round Edges - Bump
  • VRay Round Edges - Bump
    I am trying to use VRay Round Edges in addition to my existing bump map.
    Should I use a VRayCompTex and put the Image in SourceA and the VRayEdgesTex into SourceB, with ADD as the function?
    Is this the most effective way to achieve this?
    -Joel E
    https://www.biglittlepictures.com
    I've been doing it the way you described for a very long time and I don't remember having had any issues.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
      Thanks Alex, I just wasn't sure if there was a downside. It seems to be working as expected with that method.
      -Joel E
        You can also plug the material you've created in a VrayBmpMTL with an EdgesTex map as additional bump.
        A.
        www.digitaltwins.be
