composite texture bug
  • composite texture bug
    I added a black and white noise composite texture in the PHXsource >Temperature>mask> Texmap slot , to generate fire from an object according to the black and white texture, but it didn't generate so I think this is a bug.
    If I add noise texture alone it works but once I add it inside a composite texture to blend it with another noise texture, the phoenix source no longer generates fire.
    best.
    Hello,
    It works in here with a composite map blending two noises. Can you send us an example scene representing the issue?
    Thank you,
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Hey,
      I totally forgot that this was fixed in the recent nightly builds so if you get a nightly from yesterday it should work.
      Georgi Zhekov
      Chaos
