I can't get my output from vray to match exactly what's on my screen in SU. I've tried the matching viewport function, custom resolution, etc...but can't figure it out. Funny thing is that I believe things were matching earlier this month when I first started using it but no more. Any suggestions?
Vray 3 View Frame Doesn't Match SU 2017
Are you using the latest V-Ray for SketchUp version (3.40.04)?
If you've previously set Aspect Ratio to "Match Viewport", click the "Update" button and see if it resolves your problem.
Does the issue occur only in specific saved Scenes or at all times when rendering your project?
See if resetting your settings helps (the button at the bottom-left corner of the Settings panel).
Kind regards,
PeterPeter Chaushev
Let's keep in touch
Originally posted by ctastudios View Post(...) as this isn't reoccurring...yet.
On a side note, updating to the latest version 3.40.04 is highly recommended.
Kind regards,
Peter
Peter Chaushev
Let's keep in touch
