Hey Guys, I' ve got a couple of questions regarding rendering the volumetric grid in Vray. First of all, is there some more in depth documentation except the vray for maya documents, maybe some tutorials explaining the workflow, and some more in depth explaining of the parameters? Secondly, I'm not getting anything in the render elements, nothing in the normals, velocity and depth pass! I activated seperate channel for Volumetric Normals and Standard channel for Volumetric ZDepth in the Render Elements, but nothing appears! Do i have to create a new render element, or whats the workflow, so that the volume grid appears in the render elements? Do I have to render in Progressive or Bucket Mode? Do I have to set the Render Mode for the Volume Grid other than Volumetric? I tested switching to Volumetric Geometry and Progressive, but then i can't render anymore, because i get the following Error message:
Unhandled exception occurred, will exit render loop. Unhandled exception c0000005
Had a look in the forums section, but couldn't find any helpful info!
appreciate any feedback or in depth information
Thanks Guys,
Chris
Thanks Guys,
Chris
