Render with VRay 3, the Shadow study animation
  • Render with VRay 3, the Shadow study animation
    Hallo everyone,
    I need to render the sun animation (shadow study) from Rhino, with V-Ray 3.
    Is this possible? I Tried, but the shadows is always in the same place.
    How can I fix the problem?
    It is necessary that you turn OFF any lights when you start to render the one-day/seasonal sun study animation, since a 'V-Ray Directional Light' is created to simulate the Sun and its movement.
      Thanks for the answer sir Georgiev
        Did this actual fix the issue? I am having the same issue - trying to render a sun amination with Rhino, Vray 3.4 - the shadow just stays in the same place. I turned off all the lights, and it was just dark (no shadow at all). when I turn a sun on (Rhino or Vray sun) the shadows just stay in the same place and it renders a bunch of frames that are the same. Anyone know how to fix this? Did this work for you Geatano just no lights or sun lights?
          oh ok, i updated to 3.6 and activated animation and it renders out with the shadow moving as it should! progress. I do see that temporary directional light that shows up in the asset manager - it appears while rendering the frame and then dissapears. Is there a way to control the properties of that VRAY directional light that is creating the shadow, ie it's intensity color etc? Thanks
            Based the sun animation not on a physical sky&sun and the sky&sun parameters can be edited?
              Make sure the Rhino Document Sun in the Asset Editor's Light list is enabled and then edit its settings.
              Kind regards,
              Peter
              Peter Chaushev
              Let's keep in touch
