Sketchup 2017, VRAY 3.4, Windows 10
When I set up the lens effects in RGB, and then switch to denoiser, the lens effects turn off. The boxes are still checked that Bloom and Glare are on, but they are not affecting the image at all. I tried manually clicking update effects (its usually on interactive), and that does not work either. Is there a trick here or certain process of clicks that I need to follow? Thanks!
