Identical PBR materials between V-Ray and Unity/SceneKit
  • Identical PBR materials between V-Ray and Unity/SceneKit
    Hey guys, this is my first post here. I would like your help in a situation I have been facing.
    I have been working with PBR materials applied to my models in Substance Painter. When I export the maps, I work with the following set:
    - Albedo
    - AO (Ambient Occlusion)
    - Metallic
    - Normal
    - Roughness
    For engines like Unity and SceneKit, this set has worked perfectly. However, I have not been able to achieve the same level of detail in V-Ray with these maps.
    So my question is this: is there any chance I can achieve the same result I got on Unity/SceneKit on V-Ray? If the answer is "No", why is it not possible?
    Thank you very much for your attention!
    I'm wondering the same thing. Can I export a Vray material from Maya into the individual maps used in Unity / ARKit / ARcore to retain PBR details?
      Substance has an export option to vray, using the IOR map and glossiness map etc, if i remember correctly.
      e: info@adriandenne.com
      w: www.adriandenne.com
