a question about cloud coverage
  • a question about cloud coverage
    i'm simulating a simple scene about simulating cloud with phoenix fd.i find the clouds can't cover the sphere even i adjusted the brush effect to 100%.my question is how to make the cloud totally cover the object.
    Hello,
    Is this the cloud toolbar preset? If so, check the source's Smoke discharge - there is noise map there
    Cheers!
      i've ignored it.thank you,Mr.Nikolov. by the way,how can i set the final simulation as an Initial State,so i can use it in other 3ds max files?
        Ah, you can use the Load&Start button to load any cache as an initial state: https://docs.chaosgroup.com/display/...imulation-Load
        If you are going to use it for liquid sims though, make sure to get a latest nightly after Phoenix 3.05
          many thanks!
            Originally posted by Svetlin.Nikolov View Post
            Hello,
            Cheers!
            Hi is there way to make those as thunder clouds? Thank you
              A cloud like this should be easily achievable with the Large scale smoke quick preset. Maybe it would need a little bit tweaking the curves in Volumetric options (color, density, scattering...).
