I just updated Vray for Rhino to version 3.6 and I can no longer open several models which worked perfectly fine in the past.
I narrowed it down to being an issue with AutoCAD files inserted as blocks. If I rename the CAD file so Rhino can't find it, the file will open. Then I have to reassociate the block with the CAD file, after which I can work on the file and even save my work. But on restart I have to rename the link again. It will not reopen even after a save in which the file was hacked to work properly in the past. This is obviously less than ideal, especially for files with multiple block references of multiple CAD files.
Please help with a fix!
