Maya Fluids temperature
  • Maya Fluids temperature
    Hi everyone,
    I am new to vray and I am trying to do a rocket launch scene. For that I am using vray 3.6 and maya fluids.
    I manage to render the fluid adding the attribute "Vray fluid render ..." and using the phoenix fd material.
    I can see the smoke very fine, but i cannot manage to get to see the heat i configured with the emitted temperature. What should i set up to see the fire coming out and then the smokescreen?
    btw i tested already the same density and temperature configuration in arnold, and there i can see the heat. I did this to check if i was doing something wrong.
    If anyone can help, would be very nice.
    Cheers
    Tino
    Hello,
    Can you send us the scene so we can check it out?
    Thank you,
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      hi, georgi, thanks for the reply.
      How should I send it, I tried uploading it as an attachment, but it didn't work
      Cheers
      Tino
        Hi georgi,
        hiere is the scene, I hope you can help me display the emitted fire.
        Cheers
          Hey,
          I have examined your scene and the solution is quite simple. It's just that you're using a V-Ray camera with Exposure correction enabled. This makes the fire of the rocket almost invisible as it's not very bright.
          Just disable the Exposure correction in the V-Ray camera and lower down the intensity of your lighting. I have set the VRaySky to 0.05 Intensity and adjusted the Input bias of the Incandescence for the Fluid container to 0.870.
          Here is the result. Hope this helps.
          Click image for larger version  Name:	maya_2018-04-11_12-58-31.png Views:	1 Size:	172.3 KB ID:	991316
          Georgi Zhekov
          Chaos
            thanks georgi, will try this later. heading up for class.
              just another small question about the topic. If i manage to export the maya fuild as a VDB, then reimport it and use a VrayVolumeGrifMtl, can I use GPU rendering?
                Hey,
                You will be able to render VDB files on the GPU in the next major release of V-Ray for Maya, until then you can still render them in CPU mode. Unfortunately I can't tell you when this will happen though.
                Georgi Zhekov
                Chaos
                  ok thanks for the info
