Hi everyone,
I am new to vray and I am trying to do a rocket launch scene. For that I am using vray 3.6 and maya fluids.
I manage to render the fluid adding the attribute "Vray fluid render ..." and using the phoenix fd material.
I can see the smoke very fine, but i cannot manage to get to see the heat i configured with the emitted temperature. What should i set up to see the fire coming out and then the smokescreen?
btw i tested already the same density and temperature configuration in arnold, and there i can see the heat. I did this to check if i was doing something wrong.
If anyone can help, would be very nice.
Cheers
Tino
Cheers
Tino
