Grain in smoke
  • Grain in smoke
    I am using a large scale smoke emitter from a moving truck. The truck goes pretty close to the camera, and there is considerable grain in the render. Any ideas how to fix this?
    Is "use light cache" active in Phoenix render settings? If so, try turning it off or try to decrease it to 0.2 or lower.
    Lasse Kilpia
    VFX Artist
    Post Control Helsinki
      I don't see that option is it in the Volumetric settings? I am using Scanline renderer in 3dsMax BTW
        Ah ok, then I don't know. Haven't used Phoenix with scanline.
        Lasse Kilpia
        VFX Artist
          Hey,
          The Phoenix Light Cache is there for Scanline as well: https://docs.chaosgroup.com/display/...lor-Parameters
          This really sounds like your best bet. Additionally, please check if Probabilistic Shading is on and try to disable it from the Phoenix Atmosphere: https://docs.chaosgroup.com/display/...spheresettings
          Cheers!
            Unchecking Probabilistic Shading did the trick. Thanks!
              Yay! Glad it helped
