Vray Light Material or Vray Light?
  • Vray Light Material or Vray Light?
    Always wondered what the best way to recreate car lights is. Personally I create a light mesh from the geometry where others use vray light material. I always feel like using Vray Lights is more accurate but I don't know what goes on under the hood when it comes to rendering. If anyone could shed some light (ho ho) that'd be nice.
    Cheers
    CGI Artist @ Staud Studios
    There should be no difference in speed or quality between a lightMaterial emitting direct light, and a geometric light.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Ok thanks. I think using a geometric light is better in terms of being able to use light select passes and a few other options.
        Does one of both overule the other in case one has assigned a light material to a mesh used as mesh light?
          the mesh light will take the input mesh only, discarding whatever material was on it when picked.
          Lele
          Disclaimer:
