Bad mesh and how to know ?
  • Bad mesh and how to know ?
    I am making a kitchen animation and have been having problems with a flickering flat surface. It looks good in stills. Its a mesh converted from solidworks/step to edible mesh.
    i tried everything i could imagine, byt in the end I changed the mesh to my own made, and everything was working perfekt. Is there a way to check this out before you start rendering sequences?
    xView is helpful. overlapping faces, face orientation etc. check smoothing groups, unwelded verts.
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
      Thanks, will try that
        you can try increasing the secondary ray bias a little. Default is 0,0. Try 0.001. Increasing the value slightly works well for coplaner faces
        Kind Regards,
        Morne
          Your normals pass will give it away too - you'll often spot triangles on a flat surface that are a different colour from things around them which is a giveaway.
            Maybe run the Forensic script by Sini. I run it on every project and it always reveals something.
            https://sinisoftware.net/index.php?o...=12&Itemid=195
            Bobby Parker
            www.bobby-parker.com
            e-mail: info@bobby-parker.com
            phone: 2188206812
            My current hardware setup:
            • Ryzen 9 5900x CPU
            • 128gb Vengeance RGB Pro RAM
            • NVIDIA GeForce RTX 4090 X2
            • ​Windows 11 Pro
              Awesome !! Thank you guys.
