displacement without shadow casting ?
  • displacement without shadow casting ?
    hey I'm rendering a movie
    I used displacement for livelike grass
    yet the rendertimes are 8 times longer
    so... is it possible to prevent the grass from casting shadow on itself and other items ??
    thanx
    leon
    Did you try unchecking 'cast shadows' ?
    sigpic
    J. Scott Smith Visual Designs
    https://jscottsmith.com/
    http://www.linkedin.com/in/jscottsmith
    http://www.facebook.com/jssvisualdesigns
      yes offcourse
      but vray shadows doesnt seem to react
      I'm just looking for a speed-up solution
        wouldnt it just look like a bump map without shadows cast properly?
          That's what I was thinking. Except in profile, I suppose.
          sigpic
            what vray version are you at? it works fine here by uncheking recieve shadows.
            You can also try setting ray bias to greater then 0.0
            or check vray shadow bias to higher then 0.2 this will reduce shadow precision on detailed objects.
            Dmitry Vinnik
            Silhouette Images Inc.
            ShowReel:
              well it like this
              the motion is from far away to very close by
              so, far away I need the same "color/darkness" as up close
              and up closer I need the detail of the grass
              And morbid, I will try your setting in the morning
              thanx
                changing the secondary ray bias (0.0 -> 0.2) had a possitive effect on the rendertime (2:46 -> 2:22)
                the light bias didn't change anything, logically because the displacement isnt trowing shadows anymore. (cast shadow off)
                but still trying ....
