HDR skyprobe blend?
  • HDR skyprobe blend?
    I know this will be very crude, but can anyone help with ideas on how i could blend Paul debevec's skyprobe sequence together (in max) so that it can play as a pseudo-time lapse?
    Needs more cowbell
    For this animation:
    http://www.spot3d.com/vray/images/st...s/skyprobe.avi
    I used a MaxScript to render the frames with different HDRs, and then I used a Mix map with an expression controller to compute the in-between frames.
      you cant make an ifl out of the skyprobes? just curious.
        I think you could but not with the vray hdri texture. And since the regular bitmap texture doesn't give you a method of dealing with a mirror ball, angular probe or cross style source, you'd have to convert them to something like a longitude-lattitude panorama in hdri shop first.
        V Miller
          Great..thanks Vlado. I was wondering how you did that. awesome!
          Da Elf: yes, i did make an .ifl of the probes, however since they are taken at 10 min. intervals, there's only about 69 frames....so it plays in about 2 secs...i need the blending component so that i can timestretch a little
          Vance: ..exactly
          Needs more cowbell
            Vance: ..exactly
            Just render the 60-70 frames, and do your blending/time stretching in post
              Dynedain...thinking of that, but how do i deal with the building/window reflections....it's a skyscraper scene...?
              Now there are 1 minute intervals, but at 4K res each....that's around 3600+ hdrs...whoa...a little overkill for my purposes
              Needs more cowbell
                It will blur a bit, looking sorta like mblur I imagine.
                Either way, it will still seem like timelapse, and it will be a hell of a lot faster to render than the whole sequence.
                I did this 'animation' using combustion to blend between my 12 or so frames. I've done it with other assembly-type animations as well.
                http://kaadesigngroup.com/temp/vrayf...compressed.mov
                  looks awesome! what are you doing for the text? what program I should say?
                  But the project itlself is looking awesome.
                  Thanks
                  Mathew Everett
                  http://www.lappymats.com
                  Phillipians 4:13
                  "I can do all things, through Christ who strengthens me."
                    the design is not from my office, but we did do the rendering
                    the text is just a bunch of animation stuff I did in combustion. You probably can't tell because of the compression, but there's a really light overlay (heavly mblured as well) of text as a filler/filter effect.
                      ha time for me to bring this back from the dead!
                      Vlado- any chance you could share the script for rendering the frames with different HDRs? and also a more detailed explanation of the mix map and controller?
                      Chris Jackson
                      Shiftmedia
                      www.shiftmedia.sydney
