lighcache sample and filter value
  • lighcache sample and filter value
    What is the exact technique to catch the good size for a world unit?
    I have read the help file which says the param between the sample and the filter size x4/6, but I haven't understood how evaluate the size of the samples.
    I'm trying but I'm loosing time and nothing better.
    Please if someone have a good explanation.
    thx
    Laurent
    The way I set up this is as follows:
    Create anywhere in your camera view a small sphere with the approximate apparent size that you want the samples in the light cache to be. Note the sphere radius, and enter this value as the sample size parameter. From there, set the filter size to be 2 to 4 times greater than that, depending on the smoothness you want to get.
    You can then delete the sphere.
      thanks Vlado for the quick answer(two time ) I'll apply this.
      But I'm not sure of the sample good size.
      here my scene:
      the sphere seems good or bad?
      Laurent
        This should be about fine, yes. You can make it smaller for more detailes in the light cache, but usually this is not necessary.
          oh yes, thanks it works great.
          Laurent
            could u show the image please u tested with ball and relative radius used in sample size of LC?
            thanks in advance
            Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
            https://www.facebook.com/essetreddi..../photos_albums
              http://www.chaosgroup.com/forum/phpB...ic.php?t=18556
              this is the first pict, but not enough small to catch the shadows the samples were. /10 they were good but like Vlado have said not enough subd.
              cheers
              Laurent
                hi vlado
                would this also work for the size of the DE in irradiance map?
                best regards
                themaxxer
                Pixelschmiede GmbH
                www.pixelschmiede.ch
                  Originally posted by themaxxer
                  hi vlado
                  best regards
                  themaxxer
                  Yes, but only for the "World" mode of course.
