Flat Opacity for an entire object?
    Well luckily not many clients demand it. We'll be keeping the hope for this feature Vlado...
    Cheers
      you could use the multimatte render element, to mask all 3d people, then use the mask in photoshop on a solid layer.
      but it has to be rendered 2 times, with people and without, although the people pass can be rendered with low settings, no GI, etc...
      I also wish there was a direct way to do it...
      Marc Lorenz
      ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
      www.marclorenz.com
      www.facebook.com/marclorenzvisualization
        how about apply a vray light material set at 1 (or whatever looks white)
        whack a vray colour map into the opacity slot and adust
        vray properties -> uncheck all that GI affecting stuff.
        I havent actually tried this, may be a complete faliure
          ive tried that. didnt work. tried many things and nothing seems to work.
            Anything wrong with using those libraries of 2d silhouette models? I've seen plenty on Tsquid...
            • #21
              You could use Piranesi... you would get shadows in post, too.
              Bobby Parker
              www.bobby-parker.com
              e-mail: info@bobby-parker.com
              phone: 2188206812
              My current hardware setup:
              • Ryzen 9 5900x CPU
              • 128gb Vengeance RGB Pro RAM
              • NVIDIA GeForce RTX 4090
              • ​Windows 11 Pro
              • #22
                There seems to be a solution with a bit of a help from finaltoon however I just found out that finaltoon doesn't support vray proxies, or the other way around..
                Piranesi seems to be a good solution as well but it's not really feasible to export import all the renders, when you consider that these sort of line renders are mostly done at an approval stage and clients demand tons of images with the line renders..
                Here you can see what I could achieve with final toon because it supports drawing only the folding edge (outlines of an object) you can differentiate the objects from each other easily, is there a way to make the vray proxies detectable by the finaltoon, or is there anychance that we can get the vray toon detecting just the outlines of an object?
                • #23
                  Originally posted by ozztheforester View Post
                  ... is there a way to make the vray proxies detectable by the finaltoon, or is there anychance that we can get the vray toon detecting just the outlines of an object?
                  You could convert the proxy back to mesh
                  • #24
                    Yes, tried that already but when you have a few thousand proxies in the scene that doesn't work. I guess using proxies for this purpose is just out of question until a more advance version of the vray toon comes...
                    • #25
                      I am not on a computer that has max or vray at the moment. I have tried this in maya/mental ray and achieved the needed result. There is an option inside mentalray called visible to transparency and transmit transparency. They allow to get this exact result.
                      Dmitry Vinnik
                      Silhouette Images Inc.
                      ShowReel:
                      • #26
                        I did some tests in vray and also got this result. If you set vray material color to black, set refraction color to mid gray, set refraction ior to 1, and refraction trace depth to 1 also, and make the objects not visible to reflect/refract this should give the same result.
                        Dmitry Vinnik
                        ShowReel:
                        • #27
                          Thanks Dmitry,
                          Very good idea,
                          I guess this is the closest we can get to flat opacity, setting the object material is black is a bit of an inconvenience when you want to make the object pure white but I guess that can be sorted out by whitening the diffuse a bit, adding some extra lights and lighting all surfaces of the object evenly.
                          Now, if only we could get vray toon to trace just the outline of an object.
                          Cheers
                          • #28
                            Here here!
                            Kind Regards,
                            Richard Birket
                            http://www.blinkimage.com
                            • #29
                              Sorry to resurrect an old thread, but Im wondering if anyone has come up with anything in the last few years. I need to render exactly whats in the original post.
                              Silhouette people that are flat colour, but 50% opacity.
                              Ive tried the obvious techniques (opacity map, refraction etc.) But I awlays end up seeing the backs of their eyeballs and teeth
                              Invisible to refraction is undesirable as well, I need to be able to see other silhouettes through foreground silhouettes (and through glass etc). Is this still impossible to achieve?
                              Reason I want to do it in Max is that the camera will be moving as well as people walking, running, etc etc. Close by crowds of people, not just 1 or 2, more like 30 - 40 ppl.
                              Anyone have any insight in to this for 2014?
                              Thanks!
                              • #30
                                I think that this could be done in post only. Render the main scene with all People (Visible to camera Off) then render second pass only with them (V-ray light mtl or regular one with self illumination).
                                At the end you can merge everything together in post.
                                Tashko Zashev | chaos.com
