swimming pool material
  • swimming pool material
    trying to get a swimming pool material but nothing looks good.
    anyone got a mat they can post
    r
    yep, be back in 1 sec w/ it.
    5 years and counting.
      I used a brick map to get the tile pattern with splat or speckle as the map for the coloring. The file is not at hand at this moment, when I get in the office I'll post the mats.
      JoeD
      PS Here is the idea.
        Another day in the office. Here is a file with the material file, max file and wood image map. If is doesn't look right on your project it is a scale issue. I used feet, and the pool was to scale, not generic. So you may have to readjust.
        http://www.dizzy3d.com/vray_forum/pool_mat_test.ZIP
        JoeD
          yeah, sorry about me, but there was a tute for doing pools here in the old forum, i searched my personal archives and found it, so here ya go.
          have fun
          Water Recipe:
          1 Plane, segments set to 200x200
          1 noise modifier
          1 standard material, see below
          Water Material Recipe:
          1 standard material
          1 Bump, noise
          1 Reflection, VRayMap w/ Fresnel Falloff
          1 Refraction, VRayMap
          NOISE:
          Scale: 10
          Fractal: On
          Roughness: 0
          Iterations: 6
          STRENGTH:
          X: 0
          Y: 0
          Z: 1"
            psy
            for the water do I put anything in the diffuse slot? if not its a standard material with what opacity?
            also i understand that i put a vraymap in the reflection and refraction slots but where does the fresnel fallof go?
              there's a check box in the VRay mat'l/map for fresnal reflections/refractions
                here's the mat file.
                http://www.3dmaxedout.com/stuff/Water.mat
                  can't seem to open the mat file. Is it max 5? I'm using viz4. Constant bloody headache but I like the ADT to viz file linking.
                  In any case. I've got a plane that has the noise applied. I have a standard material. diffuse black. and a vraymap in both reflection and refraction slots. what are the % amounts of these and opacity level. I'm just not getting very good results. I must be retarded.
                    The mat files should be backwards compatible, I would think so at least.
                    Regardless, here's a pic of all the settings.
                    Hope it helped, and don't get yourself down, it takes a while to learn the tricks of Vray. That's what this forum is for and why people are here to help.
