If have a problem with the motion blur. Is it possible that the motion blur follows the correct frames in the animation.
As you can see in the attached jpg file, I created a VrayPhyCam with the shutterspeed of 1,0 (one second) so the motionblur is over 25 frames (pal) . But the motion blur is not following the correct animation but rather its interpolated between the 25 frames. Is it possible to do correct bend motionblur?
Carsten
Carsten
