Motion blur question
  • Motion blur question
    If have a problem with the motion blur. Is it possible that the motion blur follows the correct frames in the animation.
    As you can see in the attached jpg file, I created a VrayPhyCam with the shutterspeed of 1,0 (one second) so the motionblur is over 25 frames (pal) . But the motion blur is not following the correct animation but rather its interpolated between the 25 frames. Is it possible to do correct bend motionblur?
    Carsten
    is possible, yes. you just need more mblur samples. you can do that either globally in the vray camera global settings: vray camera>motion blur>geometry samples, or on a per object basis through the object's vray properties. default is 2, I guess you'll need quite a few more.
      Perfect, thank you rivoli, i always tried to increase the "motion blur" "subdivs" but nothing happend, but now with the "geometry samples it work. Great
