Originally posted by glorybound
View Post
You tell V-Ray with these options (V-ray Gamma 2.2 and Don't affect colors ON) to take more time rendering very dark areas, because you will later look at it with a 2.2 gamma correction applied. So it will take longer to render. But if you were to leave the V-Ray gamma at 1.0 and use other options to raise the quality just to fix noise in these dark areas then this would probably take even longer to render.
Best Regards,
Daniel
