vraylightselect to Nuke compo?
  • vraylightselect to Nuke compo?
    Hello,
    I'm struggling to find the right workflow regarding vraylighselect in a Nuke compo (3dsmax/vray).
    I will appreciate if someone can post a link or a screenshot regarding the exact process to be able to fine tune vraylightselect into a nuke compo.
    My main concern is refraction/reflexion that are embedded into the main light pass and not to each individually vraylightselect pass. So vraylightselect are useless in this case.
    Thanks
    Depending on which build you are using, the VRayMtl mateiral has options to propagate render elements through reflections and refractions; this works fine with the light select elements.
      Thanks,
      Using either 2.x or 3.x.
      You mean the option is inside the material?
      Never used such option before.
        In the "reflection" section of the VRayMtl material, there is an option "Affect Channels" - set it to "All channels"; same for refraction.
          Thanks, sounds like I will have to re-render!
