Hello all,
Is it ridiculous to think you can light an interior, with fairly small window openings, just with an HDRI on a domelight? I work with 32bit EXR, Linear colour mapping LWF, then do post in after effects, . Here's what always happens:
- add domelight with Peter Guthrie HDRI
- start optimizing using Akins theory
- add domelight into the equation and get massively frustrated that I can't get clean reuslts from the domelight, even with extremely long render times
- end up reverting to storing with irradiance map for domelight
- output to 32bit exr and heavily comp in After Effects
- get great feedback from clients but left feeling dissillusioned as an artist that I'm just not getting something right at base level!
I'll lay myself bare here with a before/after still from a typcial animation:
Its all a bit flat I think due to the light being stored, but as mentioned if not stored the noise is unacceptable from the dome light. Also I always fight against burn out, especially when there is only 1 small window like in a bedroom.
Any thoughts on what I'm doing wrong or is this all to be expected?
