In this tutorial you will learn how to use VRayBitmap, VRayUVWRandomizer, VRayTriplanarTex, Stochastic Tiling and VRayMultiSubTex to randomize the look of yo...
Cool tutorial. Thank you
Subscribed and shared it on my Facebook page as you deserve much more views )
Simply, I love to put pixels together! Sounds easy right : )) Sketchbook-1 /Sketchbook-2 / Behance / Facebook
Very nice tutorial! My only note is to maybe avoid reducing the "Blur" value for all textures, instead you can decrease the "Filter mult" parameter in the VRayBitmap texture used for normal/bump mapping - we added this parameter specifically for this purpose.
Hey Vlado, can you please explain why? This is standard practice for me since starting to work with 3dsMax in the high-end print industry.
i believe this has been discussed a load of times around here.. if i understand correctly its because it slows your rendering down, since the antialiaser has to work much harder to do the same job the image filter would. it can also lead to shimmering in animation..
Yeah, it is slower but I "thought" it is worth for the visual difference. I always reduce the blur on every map to have everything nice and sharp(not just normal/bump maps)
I will test this again like what Vlado recommended, maybe "sharp isotropic" gives the same quality as filtering off.. but it would be faster to render
Thanks for your feedback As for the blur value, I must admit I've been setting it to 0,01 forever as often times details in the the textures (esp. bump/normal maps) only show up like this. I know it increases rendertime as the AA has to do more work and you need to check for flickering in animations. I will check out these new filter multiplier options though. So the advantage is that this way you wouldn't be only reliable on the blur settings from your master node, but can still have different blur settings for the connected slave vray bitmaps?
Yes, exactly. Also, we added a new filtering mode ("Sharp isotropic") in VRayBitmap which is the default, and it keeps the details much better without having to change the filtering value for diffuse textures etc as often.
In addition that, using low blur values may also increase memory usage as V-Ray will need to load more detailed mip-map levels when using .tx files.
Generally I would only recommend changing the "Filter mult" for normal maps/bump maps to something like 0.2 to make them slightly sharper.
"Sharp isotropic" looks great!
Do you guys plan on adding "sharp isotropic filtering" to Vray 5 for Maya?
As an override filter at least, that would be great!
I was talking about this with others on Discord yesterday, pretty much everyone turns off filtering for all of their bitmaps in Maya. And for bump/normal maps >> Override texture filter >> Nearest
On another note, it would be nice to have to have the recommended settings you mentioned in the docs.
