Brushed metal (sorry, again)
  • Brushed metal (sorry, again)
    I'm new user. I made my homework, spent almost two days browsing forum(s), trying different user materials, tweaked settings, etc. but without success. I just cannot get it right. I would like to get brushed metal look like in pictures (flat metal plate behind). Can anyone help?
    Tnx,
    Jirzi
    You could try to use anisotropy (under VrayMtl-BDRF section) and glossy reflection.
      I almost tend to think this could be done with a wave-type noise map in the glossy reflections.
      LunarStudio Architectural Renderings
      HDRSource HDR & sIBL Libraries
      Lunarlog - LunarStudio and HDRSource Blog
        Tnx for your help. I tried a lot with anisotropy, but I couldn't get vertical lines in reflections. I also tried with noise map with different tiling, like suggested in one of the posts here, but it didn't look nice.
        I don't want to use bitmap, because of many objects, which all require UV mapping and then tweaking parameters. All objects were imported, so no mapping exists by default.
        BTW, what is wave-type noise map?
          To anisotropy, you need to have mapping coordinates available I believe.
          A very stretched noise map should work however. Can you show what you have so far?
            We have gotten pretty good results with the Blur HighlightOnly material
            Eric Boer
            Dev
              I use a lot of metals in my work so I made some using noise maps (as others have mentioned). I found Neal Blevins tips very useful as well.
              Here's some test renders:
              and
              And Neal's information:
              http://neilblevins.com/cg_education/.../aniso_ref.htm
              and
              http://neilblevins.com/cg_education/...c_surfaces.htm
              Hope that helps.
              - Jeff Patton -
              http://jeffpatton.net/
                heres a fairly quick attempt on my part.
                max 6 file: http://myweb.cableone.net/amylenhart...nisotest01.zip
                feel free to mess around with it as you like.
                  Hey guys, there results are great!!!
                  Tnx a lot for example, percy and for the links, pixel.
                  Now, let's experiment. I will post some results, when ready.
                  I still have to optimize render settings, whole machine renders very slowly.
                  Tnx,
                  Jirzi
