VFB Batch Image Processing - Is there a way of saving output other than EXR
  • VFB Batch Image Processing - Is there a way of saving output other than EXR
    Hi there,
    I have an EXR sequence that I need to reprocess through the VFB to apply a few changes. I'd like to save the output as PNG, but I see no option to do so. When I batch process the sequence it automatically saves out as EXR. Am I missing something?
    Thanks
    Hi, thanks for posting. As of now you can not change the sequence from exr to png using VFB's batch image processing. We will discuss whether or not to add this option. I will keep you posted.
    Vladimir Krastev | chaos.com
      Thanks! It would be extremely useful
        Originally posted by ThomasMiller View Post
        Hi there,
        Thanks
        Hi. I tried a while back, with the help of chat GPT, to make a script that uses VFB to open a folder with a bunch of vrimgs and save them as jpg. This is a modified version of that script that converts saved exrs into pngs.
        Hope it helps.
        pixel bender @ panoptikon
          Hi, for now we will not implement a png batch processing in the VFB. If this plan changes in the future we will let you know.
            Set your footage as a background in an empty scene, do your changes and render to PNG.
            Z.
