seemingly seamless/tiled patterns
  • seemingly seamless/tiled patterns
    does anyone have any ideas on how to make a large area of grass seem somewhat natural looking through vrayblend materials or composites through multiple bitmaps
    i hate the tiled look from a far when using grass textures or any image that is overly tiled
    thanks
    Have you tried adding displacement to it? I apply a VRayDisplacement modifier and find that it helps a lot in breaking up the tiling effect and making the grass look better.
      Use a mix shader for your displacement, have one slightly lighter version of your displacement map mixed with a darker one, with a third grassy map in the mix amount. The 2 main ones map at sizes which dont go into each other, like 750x750 and 830x830, and then map the mix bitmap at something much higher like 7500x7500.
      edit: Gets you a result something like this, with reasonably natural looking clumping in areas. Ignore the trees, it's an old test.
        grass
        nice grass!
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090 X2
        • ​Windows 11 Pro
          thanks for the tip! awesome grass
            any way to do this without displacement? could you do this in the diffuse slot?
              i will play, thanks for all the help here
                I tried an interesting variation of this technique. I don't have the images but I will walk you through the process. I used 2 maps for the mix maps but then I created a mask with using vertex paint. It was a fun way to play maybe overkill for many things but worth looking at if you haven't. Main problem with it is you have to have a small sub divided mesh to get clean painting.
                  Cubicle-do you get flickering when doing an animation of your displaced grass? (which looks killer btw)
                    Cubicle, what is your displace amount if you don't mind. I usually use something like 1.5" for the vraydisplacement modifier, which I take it you aren't using, but if you have any advice for that it'd be appreciated.
                    Colin Senner
                      About 250 mm - but I used two displacement maps without much contrast and mixed them with another map, so in any one area it's probably only between 30-70mm for the blades.
                      And no - no flickers at all, it was made with the intent of being used in animations.
                      tptnshp - I've not tried without displacement, it just relies on using a combination of maps in a way to add constant variation, I guess you could do it with just a diffuse.
                        cubiclegangster:
                        nice grass!!! do u use standandard UVW or world coordinate one? as far as i remember 3d displacement would not work with the world one...
                        Martin
                        http://www.pixelbox.cz
                          Cheers man - It's standard UVW maps, just stack them up. And 2d displacement, never got good results with 3d in an animation.
                            Cubicle, care to share your render settings that yield no flickers? We always have scintillation in our displaced grass...
                            • #15
                              Outstanding, Cubicle. Would you save your grass material as a .mat-file? -- Since I'm doing ArchViz, this would be great. V-Ray Fur is not really usefull, if rendering big areas.
                              --> http://www.tobyatwork.de
                              --> http://www.scriptspot.com/blog/toby
