Render Region - Creating Complex shaped render regions
  • Render Region - Creating Complex shaped render regions
    Hi All,
    I am sure we have all had to re-render just a section of an image that has updated/changed.....this is a joke!!!..... We ALL have to do it on virtually EVERY Architectural job!
    OK...I'll just do a region Render of that part.....only problem is the geometry goes from one corner diagonally to the other corner. You might as well re-render the entire image if you use only the region-render as it is a rectangle and is usless in this situation.
    Solution--
    Create a simple flat plane or spline that becomes a mask & leaves only the area you want rendered visible.
    STEPS---
    Create simple plane or spline object
    Align it to the camera [make sure rotation is ticked]
    Move it away from camera slightly [Forward]
    Move verts to create mask shape
    Assign a Vray Light material with pure black
    Turn off --- Visible to reflections, GI, Shadows,,etc ...basically turn off everything except Visible to camera
    ALL DONE
    When the render gets to the mask it renders virtually instantly as the material is as simple as it gets ...pure black.
    This technique has saved my ass many a time on a tight deadline
    Hope this helps
    Cheers
    heyyyyy ! nice idea ! i'm working right now on a arena with 12000 seats, and every re-render is a pain... i'll try your tip thanks !
    Jérôme Prévost.
    SolidRocks, the V-Ray Wizard.
    http://solidrocks.subburb.com
      It may take you 5mins to set-up your mask if the shape is complex but you can save hours of re-render time & I find it is surely worth it.
        3DMK I just wanna say thank you for the tip!. This looks like this tip gonna save me a great amount of time in rendering.
          you are a genius, thx
          sigpic
          www.Pixelvis.be
            Very nice! thanks for sharing
            Anselm von Seherr - Thoss, incendii VFX www.incendii.com
