Evermotion video tutorial mini series (Grass and Tree planting with PFlow and VRay)
  • Evermotion video tutorial mini series (Grass and Tree planting with PFlow and VRay)
    I recently recorded 3 video tutorials for Evermotion.org
    Two of them are released already, the third one will follow shortly after (Monday 02/29/2010):
    http://www.evermotion.org/tutorials/...elm-von-seherr
    and
    Hope you enjoy it
    Anselm
    Anselm von Seherr - Thoss, incendii VFX www.incendii.com
    thanks a bunch. liked the first one, downloading the second now.
      Wow...these are fantastic! Thanks for sharing!
      Troy Buckley | Technical Art Director
      Midwest Studios
        Thanks, guys! Appreciate it
        The third one is going to be "Particle Flow for Packshots" dealing with water driplets on beer bottles e.g. to suggest freshness and ice cold beverage etc. I will post a preview soon. It is over 50 minutes long
        kind regards,
        Anselm
          Awesome treat, thanks
            Yeah, these are great. I downloaded Charley's script and I'm going to be playing with this over the weekend. Thanks. Looking forward to the next video.
              Very helpful - thanks for sharing those! looking forward to the water droplet one. I've tried several times to do with Pflow and never had much luck with the drops not interpenetrating each other, or running out of memory. VrayScatter is good, but you need one for each drop shape, and that gets very cumbersome (but doable).
              b
              Brett Simms
              www.heavyartillery.com
              e: brett@heavyartillery.com
                Here is the Preview of "Particle Flow for Packshots" as promised
                kind regards,
                Anselm
                  This looks great! I can't wait to check it out! Thanks for all of the effort to put these together!
                  Midwest Studios
                    Great stuff!
                      ParticleFlow For Packshots is now released on Evermotion.org
                      http://www.evermotion.org/tutorials/...-for-packshots
                      hope you like this one as well It's almoth an hour long! thanks for watching.
                      kind regards,
                      Anselm
                        Great tutorial - thanks for making that available! The sound is a bit rough so it's hard to hear a lot of it, but the tutorial is very helpful.
                        b
                        Brett Simms
                          I agree! We had issues with the audio versus the compression since it is almost an hour long. I promise the next one will have the audio worked out Hope you can still catch what's going on.
                          kind regards,
                          Anselm
                            Hi Anselm - okay to ask a question about your use of Pwrapper on this?
                            I was trying to see how I made out with making runs/drips of liquid following your tute and wanted to try it with Prwapper. I can get it to render, but cannot get motion blur with Pwrapper, at least not in Vray. Have you had any luck with that? I think it would add a nice touch of realism to the runs.
                            Thanks /b
                            Brett Simms
                            • #15
                              Hy Brett,
                              the reason you don't get proper motion blur might be the changing topology that VRay can't handle unfortunately. I read your post at the 3daliens forum as well but santi hasn't replied yet from what i saw I would try a standard max camera and use the multi pass motionblur, that should work since it doesn't look up topology.
                              kind regards,
                              Anselm
