Adding additional subtle detail in Photoshop
  • Adding additional subtle detail in Photoshop
    Not sure if this would be useful to anyone else, but it's been something I've been using when time is of the essence to eek a bit more detail out of a rendered image.
    1. Duplicate your background layer in Photoshop
    2. Desaturate your new layer 1 and then duplicate that
    3. Invert Layer 1 copy
    4. Change Layer 1 copy's blending mode to Color Dodge
    5. Apply Filter- Other- Minimum
    6. Collapse the top two layers and apply Multiply, 30% opacity is a good starting point
    It's subtle but I think it helps.
    interesting - not far off 'unsharp mask' but seems a bit richer and without the harsh edges that can give
      That is one clever trick, thank you for the tip.
        Sweet! Thank you for that tip. just tried it on an older render. adds good detail
        cheers,
        Anselm
        Anselm von Seherr - Thoss, incendii VFX www.incendii.com
          Very cool. Thanks!
            Any chance to see example pic and clear pic ?
            Thanx
              Sure. Here you go.
ID:	843038Click image for larger version
                Another controllable sharpen method, basically the same idea:
                1 - duplicate the layer
                2 - (optional) Convert to smart layer
                3 - High pass filter
                4 - Overlay blending mode
                5 - tweak your high pass radius, and your layer opacity to control the amount of sharpening
                6 - paint yourself a mask to have different levels of sharpening on different parts of the image.
                Dave Buchhofer. // Vsaiwrk
                  Yes. Subtle, but nice! I just tried it.
                  Bobby Parker
                  www.bobby-parker.com
                  e-mail: info@bobby-parker.com
                  phone: 2188206812
                  My current hardware setup:
                  • Ryzen 9 5900x CPU
                  • 128gb Vengeance RGB Pro RAM
                  • NVIDIA GeForce RTX 4090 X2
                  • ​Windows 11 Pro
                    I just tried it as well. I was so curious I just had to see it. I like it as a starting place definitely.
                    Colin Senner
                      Excellent, used it already, can also create a 'pencil sketchy' feel as well!
                      laters
                      spike
                        great tip, thanks
                          I'm glad that it's of benefit.
                          So far I've found it to be useful for stills only; too many issues when compiling video frames run through a batch. Then again, I haven't moved far into the realm of HD video yet.
