V-Ray 2.0: VRayHDRI vs Bitmap texture and the bitmap pager
  • #16
    Someone needs to write a script to convert max bitmap loader to vrayHDRI loaders...... anyone??
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
    • #17
      Right-click in a viewport > VRay Bitmap to VRayHDRI converter...
      • #18
        Far too easy vlado
        Chris Jackson
        Shiftmedia
        • #19
          Hehe. In any case, be careful with this script. Would be good to save a copy of the original scene with the Bitmap textures just in case.
          • #20
            The new capabilities of the vrayhdri loader sound great with regard to opening it up to other file formats. But why not just add another map called "vraybitmap"? I'm just looking at it in a clarity of naming type of way. Naming things for what they do. I think there is potential for people to overlook this important update.
            Just curious
            V Miller
            • #21
              The problem with loading them as vrayhdri maps is that you have little control over any map parameters (like the curves, etc). Has this changed in 2.0?
              Colin Senner
              • #22
                Nope, although I made a note to add them. Still, you can use an Output map for more control.
                • #23
                  Thanks for the info Vlado!
                  Colin Senner
                  • #24
                    Hi Vlado,
                    very intresting. So, the correct way for better performance with bitmap in any map channel (diffuse, specular etc...) is:
                    ColorcorrectMap->OutputMap->VRayHDRI
                    in fact we use always, before bitmap, add a neutral ColorCorrect map
                    www.francescolegrenzi.com
                    VRay - THE COMPLETE GUIDE - The book
                    Corona - THE COMPLETE GUIDE - The book
                    --- FACEBOOK ---
                    • #25
                      May I ask why?
                      Set V-Ray class properties en masse with the VMC script
                      Follow me for script updates: @ollyspolys
                      • #26
                        It's simple. We have more control over the bitmap.
                        Without use photoshop, we can change a bit the bitmap look.
                        The best will be have in the colorcorrect map level and curve adjustment
                        Anyway, neutral because I don't know if I need to change the bitmap properties. Right now i do this automatically
                        Sometimes I need to change some properties (hue, saturation etcc...) sometimes no.
                        --- FACEBOOK ---
                        • #27
                          Sounds good.
                          So to clarify Vlado, we'd all like a vray bitmap loader that combines all of the colour correction map capabilities and the native bitmap options, such as cropping and curves. All accessible by maxscript. When can you have it ready by?
                          Only kidding, but seriously this would be a real power map; do you think it's possible to include in 2.0?
                          • #28
                            +1
                            ehh...
                            --- FACEBOOK ---
                            • #29
                              Sounds good.
                              Not for the release obviously, but it might make its way into a service pack.
                              Best regard,
                              • #30
                                Hi Vlado,
                                will be one of the usefull shader for max XD
                                --- FACEBOOK ---
