Reflected Environment Set up- Tutorial
  • Reflected Environment Set up- Tutorial
    Reflecting materials are very common, if the environment set up right then the reflections would be more realistic.
    There's lot's of techniques to do so, for example: HDRI, Backdrops/Billboards.
    So here one way of setting the Environment.
    Note: Loading images can take a few moments and longer on slower internet providers.
    Resoult
    I hope this tutorial was productive for VfSU users.
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
    Re: Reflected Environment Set up- Tutorial
    wow. thanks 40th.. really good. here is much clearer even.
    http://www.nomeradona.blogspot.com/
    http://www.sketchupvrayresources.blogspot.com/
    http://www.nomeradonaart.blogspot.com/
      Nice tutorial.
      I didn't realise you could resize objects with the tape measure. That's awesome. If I only had know that earlier...
      p.s. for your curtain wall, if you add a slight bulge bumpmap you increase the realism as window surfaces are never perfectly flat. some distortion happens.
        Originally posted by thomthom
        Nice tutorial.
        Thanks Thom,
        Yeah those little tips/tools make a huge difference in the workflow and modeling
        About the bumpmap,i totally agree with you i tried to add displacement but it required too much RAM memory (i have 2gb) so it crushed :-\
        www.Top3Dstudio.com
        SU 8
        VfS 1.48.89
        Win 7 64-bit
          you are the man. 40th. very clear & nice tutorial u put together. u rock!!! 2 thumbs up!!
            Hi Guys,
            How do you get your shadows so soft? and those trees! wow, could you tell where to find them.
            What is bulge mapping? is this different from displacement.
            Thanks.
              artchung, you are too kind
              Tomass,
              1.For soft shadows i increased sun size to 6 an and shadows subdivs to 16 (http://www.spot3d.com/vray/help/150S...raysun_sky.htm).
              2.Trees are Xfrog trees (http://asgvis.com/index.php?option=c...0&topic=4684.0)
              By bulge he meant Bump/Displacement map.
              www.Top3Dstudio.com
              SU 8
              VfS 1.48.89
              Win 7 64-bit
                Originally posted by 40th
                Thanks Thom,
                You don't have to use displacement. Bumpmap is enough so that the reflection distorts.
                  Thanks for the tutorial! And for the tape measure tool tip!
                    Thanks Thom,
                    Thanks for the tip Thom, here it is
                    www.Top3Dstudio.com
                    SU 8
                    VfS 1.48.89
                    Win 7 64-bit
                      ;D
                        and the sky reflection???? how do you made that.... because i can´t make apear the sky on my glass reflection
                          For sky reflection you can use Vray sky, but it won't give you clouds. So i used an HDRI image for Environment background.
                          www.Top3Dstudio.com
                          SU 8
                          VfS 1.48.89
                          Win 7 64-bit
                            ok....I will try with HDRI ..... BUT DO I HAVE TO MAP THE HDRI? How do I do that... ???..Can you make a tutorial? or just put the hdri and that it....I want some cloud on my glasses but I couldn’t make it yet.... :-\ ...however....thanks for your advices ;D
                              Link to the HDRI- http://rapidshare.com/files/15627304...017_L.rar.html
                              1. Environment>Background>Click on the 'M'
                              2. Select 'bitmap' under type
                              3. Click on the 'm' and select the image from it's location on the hard drive.
                              4. Under UVW select Environment, and spherical under mapping
                              5. Under multiplier type the intensity/brightness of the image (the number depends on a lot of variable- if you have physical Camera turned on then you have to bump the multiplier to thousands)
                              *For adjusting the HDRI to the sun direction use the Horizontal Rotation (in my case i used 45 degrees).
                              That's it
                              www.Top3Dstudio.com
                              SU 8
                              VfS 1.48.89
                              Win 7 64-bit
