how to get effect like this in vray
  • how to get effect like this in vray
    please help me for get effect like this on picture
    Try to use a lens effect in MAX or photoshop for postediting.
    Andras
      Re: how to get effect like this in vray
      I would not began to do it in Max. Easier in any editor of photos... From Photoshop up to Combustion...
        thanks for reply
        can you write me how do it in photoshop
          thanks for reply
          Filter>Render>Lens Flare
          It is better to do a glow, for example, in Aftereffect or Combustion.
            This is normally done in post using a program like Combustion or After Effects. You can play with the effect with out having to render out a sequence from max every time you want to make a change. Speeds this up a lot.
            Cheers
            Mike Kennedy
            Two heads are better than one ...
            ....but some head is better than none.....
