Mapping
  • Mapping
    Ok, I've a simple question.
    How can I map a cube with different materials applied to different faces?
    Thanks!
    Re: Mapping
    Yes!
    Just explode the cube bengiamin!!
      Re: Mapping
      Originally posted by zuperZE
      Yes!
      Explode is'nt good decision ;D Vray does'nt love exploded objects. You may use different mapping channels for each cube side. Then you should adjusting them manually
      There's other variant. You may try to unrapUVN the cube, and then in PS you may apply textures individually
        Re: Mapping
        Explode is a good option. why not? apply different materials to each side of the cube and edit the texture mapping keeping all of them with a single channel. Just adjust the rotation and the position of the Mapping widgets.
        www.leobonilla.com
          Re: Mapping
          Thanks!
          Does All the materials you want to apply include Textures? or they are simply Textureless materials?
          www.leobonilla.com
            Re: Mapping
            I would like to understand the method using different channel in diffuse. Is there any kind of tutorial? I'm breaking my head!
            Well, exploding the cube is a solution...but it's an extreme solution, I wouldn't like to explode anthing.
            So...what about different diffuse channels?
            Thanks
              Re: Mapping
              if you explode the edges may become jaggy, they wont render seamless
              My Vray for Rhino Gallery Updated 2011 Toon and Gold&nbsp; Comments are Welcome<br />http://ozanbdesign.tumblr.com/tagged/Rhino My Tumblr Rhino Gallery
                Re: Mapping
                Workaround: extract render mesh and than extract the needed mesh parts/faces. So, the connection between two faces are not jagged.
