window reflection
  • window reflection
    Someone school me on the best way to get good looking windows... What are you guys using?
    Eric Camper
    Studio 3D
    www.dbfinc.com/studio3d
    good hdri and mask the glass for post PS tweaks. I layer images until I get something I like
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      believe it or mot, never did any maskng... can you ellaborate a little for me.
      Eric Camper
      Studio 3D
        Once you are used to masks you will always use them
        You could use the MultiMatte renderelement, assign an object id to all your window glass and set this id to one of the rgb channels of the MultiMatte. You will end up with an image file you could use in photoshop to get a perfekt selection of your windows by using the rgb channels. Or you could take a look at the psd manager from cebas which will automatically creates mask and layers of your rendering. Another quick method would be to assign a white material to your windows and black to everything else (or delete the other stuff in the scene) and render out a quick scanline rendering which you can then use to get selections in photoshop.
        www.short-cuts.de
          is the way I go. I forgot to turn it on for the last image I did, so I had to mask old school, which tok forever.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            also what you could to is render the wirecolor element, you just have to make sure your object have different wire colors, (these scripts out there to assign random wirecolors)and then you use your magic wand to select colors in ps.
            PLAY
            www.kriscabrera.com
            kris@kriscabrera.com
