Texture size
  • Texture size
    Applying textures - "differences"
    Ciao!
    Intel(R) Core(TM) i7 975 Extreme Edit. 3.33GHz / 6.4GT/s 8Mb box / Motherboard Gigabyte GA-EX58-UDS / Asus GForce GTX275HDMI 896DD3 (12Gb) / Windows 7- 64bit / Sketchup 2013 / V-Ray
    Yea, I often do that. Apply low res textures in the main diffuse channel as that's the texture that will be saved with the SketchUp file. Then I make that transparent with TexAColor and add a high-res diffuse underneath - which is just linked to the file on disk. Make the SketchUp model much more responsive.
      good idea!
      Thanks for this method, this will be very usefull!
      V-Ray for SketchUp 3.4
      Windows 10 pro 64-bit.
      french
      SketchUp 17 french, artisan,fredo scale....
      intel i7 4790k
      geforce GTX 980
      Ram:32 g
        Excellent tip!
        /Jackson
        SU 2018 + VfSU 4.0
          How do you do this method?
          Like this?
          french
          intel i7 4790k
          geforce GTX 980
          Ram:32 g
            No, you have to load a 0,0,0 white "TexAColor" into the transparency slot. This tricks SU into displaying the Diffuse Layer 1 low-res texture while V-Ray renders the Diffuse Layer 2 high-res texture. It also means your skp file will be much smaller as only the low-res texture is saved while the high-res one is simply linked. Because of this however, it can make moving skp files across networks complicated as all linked files and paths must be replicated.
            SU 2018 + VfSU 4.0
              ok thank you
              french
              intel i7 4790k
              geforce GTX 980
              Ram:32 g
                nice! thanks for the tip
