showing exterior from inside
  • showing exterior from inside
    How can i show an exterior from inside a room. i can put a plane with an image in front of the window but then i loose my sunllight. I know it can be done bbut how?
    Regards, Rene
    The sun isn't the problem since you can disable "cast shadow" for the photo plane. But my problem often is that I like to get the lighting from a HDRI env for correct lighting the room and the background plane blocks the GI light. Trick to keep the GI: set the photo background plane material 99% transparent and rise the emitter multiplier until it is visible again + set background env black and instead use refl/refract env. But in this case the background plane could send some GI light into the interior. But it could work for you.
    I don't know why it is so difficult for Vray to support all typical options like disabling/enabling GI, Reflection, refraction, camera, shadow ... . Could be great if the development team could think about to complete this kind of options.
      Thanks Micha
      i am a bit in the dark here. You do use a plane with a bitmap on it? Them you make the plane transparant and apply an emmitter layer?
      A manual which does not go as deep in the technical details as the vray manual would really help. A manual that for instance says when you increase the min subdivisions you will have less noise at the expense of longer rendertimes.
        Yes, set the emitter layer transparency for example at 250,250,250.
