uv
  • uv
    hi
    i paint in blender texture for glass
    please help how can use it for ref glossiness
    Use "Mesh Vertex Channel" node.
    andrei.izrantcev@chaos.com
    Support Request
      thank you
      in node editor
      some node only found if you search in normally not show
      such as:mesh vertex channel or gamma
      and in vray i can not use some blender node such as invert or other converter
        sorry i found inverter but only when i search it
        Originally posted by dp_mg42 View Post
        thank you
        in node editor
          Yes, V-Ray has its own nodes, only a few Blender nodes are supported.
          Hm...
          Support Request
Name:	QIP Shot - Screen 001.png
            see i don't have it
            and
            in vray mtl
            i don't have opacity !!!
              sorry
              before vray in blender
              i use vray in max
              in this section
              i try create grill
              i download the pic and i need to introduce to vray to transparent black part of picClick image for larger version
              [ATTACH=CONFIG]22085[/ATTACH]
              see i don't have it
              and
              in vray mtl
                This issue is already fixed, update your build and you will see all the textures.
                Also "Mesh Vertex Color" texture is not for providing UVs - it is used to visualize UV or Vertex Color.
                You need to connect nodes from "Mapping" section to the "Mapping" sockets (for example, "Channel (Named)").
                Black parts will not become transparent on their own. If you have this texture with alpha channel you could connect "Out Alpha" socket to "Opacity".
                Otherwise you'll need a separate texture to represent opacity.
                You could also show your 3dsmax material setup and I'll show you how to reconstruct it in Blender.
                Support Request
                  thank you so much
                  i use 2.72.2
                  newer?
                    i use 2.72.2
                    newer?
                    Just download the last build you could find at the nighlies server.
                    Support Request
                      thank you
                      for example this material
Name:	QIP Shot - Screen 002.png
                      and
                      in blender we have sapling add-on
                      it generate trees
                      in blender v-ray i can't texture it can you help me
                        and in car paint shader how can control flake size and amount?
                          What is the exact problem?
                          Everything that could be textured is located on the node (sockets), everything else (values) are located at the "N"-panel of the node editor:
                          Support Request
                            when create tree
                            all leaves are one object
                            and i need to tell to vray
                            texture leaves individual
                            thank you about carpaint
                            [ATTACH=CONFIG]22147[/ATTACH]
                            • #15
                              and i need to tell to vray texture leaves individual
                              You want to randomize textures/materials? Check node examples here:
                              https://github.com/bdancer/vb30/wiki
                              and those links:
                              https://github.com/bdancer/blender-for-vray/issues/30
                              https://github.com/bdancer/blender-for-vray/issues/78
                              Support Request
