Learning of interior rendering
  • Learning of interior rendering
    Hello, I have few question, and want to learn interior rendering, for start.
    1. What should choose maya or max compatibility for exporter that are given option in blender exporter.
    2. Are portals really necessary, if yes simple portal or portal would be better.
    3. what better to use:
    a) World for GI lighting,
    b) Hemi (dome),
    c) both with same hdri image.
    4. what GI primary and secondary engine should be:
    a) for speed
    b) for quality
    For interior rendering I use an hemi with a world with the same hdr image.
    For GI, it depends on the scene. Interior renders could be long to render, check the documentation here.
      thank you for answer, next question how to render particles lets say hallo spheres whitch are lightint, and dont whant to see emitter, I am asking because in particles panel render section, emitter ticked on or off, result are the same vray renders emiter with particles
        if i choose particle type Hair, than emitter plane can be controled to be visible or not in renderin proces, is that a bug or my mistake
          Update your exporter and there is no bug anymore.
          Win11 Pro 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
            Thank you for advice, some times exporterupdater writes git error.
            I whant to ask how to get only light pass layer, for glow wfect purpose in post production
              "Color Channel" node, then select "Type" you need.
              andrei.izrantcev@chaos.com
              Support Request
                thank you, bdancer, next question, how to acheve DOF?
                  1. Camera -> Parameters -> Use Depth Of Field
                  2. Camera -> Physical -> Use DOF
                  + tweak settings
                  Support Request
                    how to atcheve lense glass efect, and how to get energy preservation effect
                      Use V-Ray Frame Buffer's "Lens Effects".
                      Have no idea what is that =)
                      Support Request
                        http://docs.chaosgroup.com/display/V...nModeParameter
                        about energy preservation
                          "Standard Material" or "BRDF VRayMtl" "Energy Mode" attribute.
                          Support Request
                            [ATTACH=CONFIG]26823 I have problem, rendering on two computers, with 2 nodes, and tiles are not the same color tone, that will see verry clear on the wall
                            • #15
                              by the way render slave is ubuntu, master computer is macintosh
